removing fuel
removing fuel
i need to remove the fuel from m 89' formula i have the syphon but i cant get the tube into the fuel tank for some reason. is there a screen down there blocking my way? is there some trick to getting the fuel out of the tank?
I couple months ago I had to replace the fuel pump in my '91 Formula. To siphon the tank I stuck a piece of plastic tubing down the filler hole. I had to twist and play with the tube a little to get it down there. There wasn't any screen, but I think there is a lip where the filler neck attached to the tank body. Try putting a gentle bend in the hose and when you hit the obstruction, try turnign the hose. Also the sending unit, fuel pump, etc is right in the way, so you have to snake the hose around them. Hope this helps, good luck.
NBrehm
Aug 25, 2015 11:49 PM
