how noisy are full roller rockers?
Old Feb 24, 2005 | 09:02 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I have afr 195 heads, 1.6 narrow body full roller rockers(for center bolt heads, hardened pushrods and roller lifters
I checked and nothing seems to be hitting. geometry is right on. it sounds like very very loud injectors. I put the valve covers on thinking it would get pretty quiet but, it is still there (same on both sides and all rockers)
I guess I would like to know what the noise level should be
Old Feb 24, 2005 | 09:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
With a hydraulic cam there shouldn't be any noise.
How about the 1.6 ratio. Is it creating too much lift and the bottom of the spring retainer is hitting the top of the valve guide? Throw on a set of 1.5 ratio and see if the noise goes away.
Old Feb 24, 2005 | 09:29 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
My 1.6's are very quiet. make sure that they are adjusted right.
Old Feb 25, 2005 | 08:18 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Mine have always made a little bit of noise just like you described. I thought there was a problem at first but after readjusting them a few times and checking to make sure nothing was rubbing or hitting I have come to the conclusion that its just the rockers making a little noise. Its been doing it for about 3000 miles now and I havent had any metal in my oil and the car runs great so I think everything is normal.
Old Feb 25, 2005 | 09:31 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I had noise with my Crane Energizer roller rockers when I first tried them three years ago... I took them off because I didn't like the noise.. I recently reinstalled them on my GTA, but this time I adjusted them correctly (e.g. make sure that once you get zero lash, do a half turn, then tighten the set screw, THEN tighten the nut and the set screw (it will end up being like 1/8 of a turn) together).. Doing it like this makes sure they don't loosen.. Now they sound just like the standard rockers I had on before... If you adjust them right, you shouldn't have any noise...
Old Feb 26, 2005 | 08:52 AM
Engine: ls1, LB9
why are they so hard to adjust? I have set stock rockers for years! never had a problem with stockers
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
ericjon262
Sep 11, 2015 06:07 PM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
