Stock Crankshaft Use it or lose it?
Old Jul 6, 2001 | 02:28 PM
icenine9's Avatar
Overall the 350 i am working on doesn't look in bad shape at all. Would it be safe to use the stock rods and the crank in an engine with over 300hp, or should i get a new cast crank and stage 1 or 2 rods?
Old Jul 6, 2001 | 02:34 PM
Grand Prix's Avatar
Nothing wrong with the stock cast crank. I wouldn't toss a GM original crank for a cheap Scat or other crank anyways. Well maybe if we were talking a stock cast crank versus a cheap forged crank or something. Stock rods and cranks have taken up to 500HP. Just make sure they are all in good shape. If it worries you and you have a little money to play with there are things you can do to improve the strength. If you polish the rods and shotpeen them it will improve their strength. Have the crank turned with a generous fillet at the ends of the journals and then polish the entire crank. While it is being turned have them shotpeen it as well. I don't think any of this is required for an engine in the 300HP range but if it gives you peace of mind then go ahead. Just be aware all of this changes the engine's balance. I wouldn't do all this without balancing after it was done.
[This message has been edited by Grand Prix (edited July 06, 2001).]
Old Jul 6, 2001 | 03:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
300 HP from a 350 is nothing to worry about stressing the bottom end, I would not hesitate to use a stock crank and rods for that.
ICON Motorsports
Old Jul 6, 2001 | 03:20 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
As is...you should probably have it checked out and turned if needed, as well as having the rods resized.
You may already have this in mind, but I kinda took your question as reusing the orginal parts w/o reworking them.
midge54
Dec 27, 2019 04:14 PM
Genopsyde
Oct 7, 2015 08:35 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
LT1Formula
Aug 20, 2015 09:36 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
