What size of a socket??
Old Feb 25, 2005 | 09:54 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
What size of a socket i need to remove the main nut holding the alternator fan blade?
Old Feb 25, 2005 | 02:25 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I believe it is 15/16
Old Feb 25, 2005 | 02:58 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Might need air tools... that $#@&!@ is on there tight!
Why are you trying to remove it, anyway?
Old Feb 25, 2005 | 09:37 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Could someone verify that for sure?
I want to polish my alternator.....
Old Feb 25, 2005 | 10:13 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Can't you just go out and start sticking sockets over it to see if they fit or not? When I had to remove mine, it was a fairly large nut. 7/8 or 15/16 sounds right.
Old Feb 25, 2005 | 11:26 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I wish i could..The largest socket i have is 22mm
Old Feb 26, 2005 | 01:28 AM
ZZsmpch's Avatar
Unless you are comfortable taking the alt. completely apart to polish the case, I'd suggest leaving it alone. The filings will destroy the bearings and can also damage the internals.
Old Feb 26, 2005 | 08:14 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
I checked, 15/16 for sure.
Old Feb 26, 2005 | 01:50 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Yes, i will take it all apart and thanks for double checking the nut for me. Now, i will go ahead and buy that socket..
Old Feb 26, 2005 | 03:42 PM
Vader's Avatar
Make sure you get the Allen wrench or Torx bit you need to hold the alternator shaft while you turn the nut. It's going to be pretty tough with a socket, which is why I like a wrench instead. You'll learn to appreciate anti-seize compound after doing a few of these, too.
I suppose you could spilt the case and hold the alternator rotor in a vise to turn the nut, but use catution not to distort the rotor pole pieces. An imbalanced alternator rotor is a grenade with a loose pin....
Old Feb 26, 2005 | 03:45 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I take them off with a impact wrench, usually they are on there so tight and rusty that a regular wrench is is often useless.
Old Feb 26, 2005 | 03:53 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Yep, an impact gun is the way to go. BTW, I just tryed a 15/16 on my 1987 alternator & it fits perfect.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
