Dumb Question I'm Sure...but would like to know
Old Feb 25, 2005 | 09:22 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
i have an 84 TA with L69 engine....on any other car i've been in when u turn the key so it's just on power u hear the fuel pump humming or whatever, when it turns on.....i noticed that my car doesn't do that and i checked the fuse panel it has a label for the F.Pump but there is no fuse nor any connector to put a fuse in....so what do i have??
Old Feb 25, 2005 | 09:34 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Since your car's an 84, it should have a mechanical fuel pump. Mechanical fuel pumps run off of an eccentric on the front of the camshaft, so of course it's not working unless the engine is running/turning over.
Old Feb 25, 2005 | 10:35 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
Benm109 is right about the pump unless the carb was scraped for a fuel injectoin setup
Old Feb 26, 2005 | 01:21 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Carbs require 5-8 psi fuel pressure so a electric fp is not required. All earlier carbed 305's had mechanical f's, i'm not sure about the 87's?
Old Feb 26, 2005 | 01:27 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Later years (post-86), GM started to install in-tank helper pumps to assist in the vapor lock issue.
Old Feb 26, 2005 | 04:50 AM
smokefan's Avatar
i didnt know if it was a efi swap or not.
Old Feb 26, 2005 | 07:15 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
My 84 Z28 with an L69 had an intake helper pump in the tank from the factory. Eventually the rubber hose from pump to sending unit split causing lots of fun. I don't know if it's supposed to prime with key on, but with the car running I could hear it was on by listening back by the gas tank. Your car should have the same. If you look at the wires going to the sending unit in the tank, it should be a 3-wire pigtail with the helper pump and a 2-wire pigtail without.
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
