Power Steering Pulley Puller
Old Feb 26, 2005 | 04:14 PM
slow91camaro's Avatar
Car: '91 Camaro Z-28
Transmission: auto
Need a little help here guys.
My alternator bracket broke so I need to pull the pump to replace the bracket. I bought a cheap $20 puller from Pep Boys but it was worthless. I borrowed a snap-on set but there just isn't enough room to use it with the radiator still in.
I used to have a cheap system that came with my supercharger that worked great for pulling the pulley, but I sold it along with my supercharger. Do any of you know where I can get puller that will get the job done?
Thanks in advance for any help.
Old Feb 26, 2005 | 05:59 PM
Transmission: auto
Never mind, problem solved.
All I needed was the cheap puller, a grinder to manipulate the cheap puller, a 1/4 extension and a couple of c-clamps. Still, if anyone has had success with the "right" tool, I might be able to find room in my tool box for it.
Old Feb 26, 2005 | 08:23 PM
Damon's Avatar
The "right" tool works a whole lot better with the pump/pump bracket OFF the car for the exact reason you describe- tool is too long to use it in-car most times.
Old Feb 26, 2005 | 11:04 PM
Transmission: auto
You're certainly right. For some reason I thought there was a bolt hidden behind the pump that would keep the bracket on, but in hind site there wasn't. At least I didn't have to deal with the mess of pulling the power steering lines.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
sailtexas186548
Aug 24, 2015 10:11 PM
