What should be the correct cycle rate on ac clutch?
Old Jul 7, 2001 | 03:59 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
anyone? I replaced the pressure valve on the ac with an adjustable one and I cant seem to get it to cycle at the correct rate. I need to know how many times per minute or what have you it should cycle.
SSC
Old Jul 7, 2001 | 04:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
AC compressor will cycle depending on head pressure. When the pressure builds up too much the high pressure cutout switch will disengauge the clutch. If there's little to no air flow across the condensor, the clutch will cycle more than normal.
Old Jul 7, 2001 | 07:52 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Thats what I was thinking so I need to back the screw off a bit.
Thanks Stephen.
SSC
Old Jul 7, 2001 | 10:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The proper way to set it is with a set of ac gauges to watch the pressures.
Drone358
Dec 10, 2015 08:16 PM
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
