alignment specs
Old Jul 9, 2001 | 06:59 PM
R.O.B.'s Avatar
alignment specs
I need an alignment on my TA (thanks to a friend). What are the stock specs, and what would be a good recomendation for mostly handling tight corners.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Old Jul 9, 2001 | 08:24 PM
82camaro's Avatar
Car: 82 camaro SC
Stock specs suck for the most part so I won't even bother.
The specs I like:
-.5 camber
+4.5 degrees caster left
+5.0 degrees caster right
toe + 1/16inch
If you drive alot nicer change the camber to -.25 degrees.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jul 9, 2001 | 11:22 PM
Guest
Guest
Posts: n/a
I agree with the above assesment but you probably wont be able to hit that caster number. Whatever you do, do NOT run the factory spec of +1 degree camber unless you like wearing the outside edges of your tires. -.25 to -.5 is good. And depending on the wear on your front suspension stuff, 1/16 toe in might make the car wander a little.
Old Jul 10, 2001 | 07:49 AM
82camaro's Avatar
Car: 82 camaro SC
Some cars can get the caster and some can't--forgot to add that part. The stock specs are terrible even for a mild 'grandma' driver.
82camaro
Old Jul 10, 2001 | 11:13 AM
R.O.B.'s Avatar
Thanks guys, I'll go with that.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
