TPI splutters when cold....help
Old Jul 10, 2001 | 01:46 PM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
My 89 IROC 5.7 TPI idles very rough and splutters when I accelerate when cold. When I drive for a couple minutes it runs better with just a little hesitation off idle, but when it's cold it's bad and it coughs through the intake. It started doing this after I changed injectors. I checked for vacumm leaks but couldn't find any. I also checked for any loose vacumm lines and couldn't find any. Any suggestions?
2000 NHRA Edition T/A
Pewter Metallic
A4 3.23 Gear w/GSC's
Whisper lid, MAF Ends, Ram Air Kit, Exhaust C/O
Best 60ft:1.94
1/8th:8.381@86.03
1/4:12.963@108.44
1989 IROC-Z 5.7
Auto w/3.24 gears
Old Jul 10, 2001 | 01:58 PM
irocbsa's Avatar
Does it sputter or splutter? We need to know these things man.
But seriously, is the car showing a check engine light. Have you scanned for codes. The hesitation off idle seems like a throttle position sensor problem to me.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jul 10, 2001 | 02:03 PM
Dano 00TA's Avatar
Engine: LS1/L98
Nope, no check engine light. I scanned for codes and got none. On another board someone said it could be a dirty injector but I figured if it's a dirty injector it'd run rough all the time. I have another TPI setup and was thinking of changing the throttle body and see if that helps.
Pewter Metallic
Best 60ft:1.94
1/8th:8.381@86.03
1/4:12.963@108.44
1989 IROC-Z 5.7
Auto w/3.24 gears
Old Jul 4, 2013 | 12:27 AM
Nasty9Iz28's Avatar
Car: 1991 z28 camaro
Engine: 350 tune port injection
Axle/Gears: 3:42
Re: TPI splutters when cold....help
I'm having the same problem on my 91 camaro z28 5.7tpi 5 speed and it started happening to me when I deleted my smog pump and put headers on it, did you ever find out what it is?
Old Sep 27, 2013 | 08:35 AM
alexiroc's Avatar
I have the same problem on my '89 305 TPI. when it warms up, its great. Am guessing its either the a) EGR valve stuck, b) Vacuum leak, c) Coolant Temp sensor or d) Manifold Air temp sensor. Anyone know what the symptoms of a bad Manifold Air Temp sensor would be? I have not check engine light most of the time, the light only goes on during a cold day and sitting at a red light., then goes off. Any ideas.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
