thermostat ?
Old Mar 7, 2005 | 11:20 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
thermostat ?
I changed my stat to a 180 recently without changin the PROM, will this cause any serious problems? should i learn how to do proms and fix that or am i ok and nothing serious will happen?
thanks
Old Mar 8, 2005 | 12:49 AM
ecuxc's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
you wont have any problem, I put a 160* in mine, no codes thrown.
Old Mar 8, 2005 | 05:13 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
A thermostat, no matter what the temperature, does not throw a code. Run without one, it won't throw a code. What it does do, is help alter the amount of fuel the injectors dump in - courtesy of the coolant temperature sensor. Based on a preset temperature list, the ECM alters how much fuel to put in. Run colder that what the ecm is "used to," so to speak, and the ECM will dump more fuel than what is really required.
A 180° thermostat should be fine. If it were my engine, I would reprom for a 160°. But that's if it were my engine.
Old Mar 8, 2005 | 04:56 PM
BCdawg57's Avatar
so what youre saying is, it wont hurt my perfomance, just my mpg
Old Mar 8, 2005 | 05:03 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Tiny improvement in performance.
There is a down side tho.
Since your oil and everything else does not get up to full temp, many of the compounds that would be burned off or evaporate are left behind. It won't happen overnight but over the span of 50K it will wear out quicker and sludge up.
I wouldn't go down all the way to 160, 180 is my limit and that is no panacea either but a comprimise.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
