What oil pump for 350 build?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
The farther I get into this project, the more things I'm figuring I should replace!!
With a 69 350 block, Holley stealth ram, trick flow heads, etc., should I run a stock oil pump, or should I replace it while I have the motor out?
What one should I get? Is there anything else I would have to change??
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Maybe I should just PM you instead of posting
So this one?
http://store.summitracing.com/defaul....asp&x=24&y=10
Stock replacement. If that's all I need, sounds good to me!
So this one?
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
- Melling M55 oil pump (MEL-M55)
- Melling 55s pickup screen (MEL-55-S1)
- Melling IS-55e hardened driveshaft (MEL-IS-55E)
- Mr. Gasket #26 pressure spring (MRG-26)
That's about all the oiling system a small block chevy will need, given no added oil clearances or added flow volume.
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: What oil pump for 350 build?
i know this is a very old thread but would all of those items fit a 93 350 block...
Car: check
Engine: check
Transmission: check
The M55 is no longer recommended for a high performance engine. Since this thread originated Melling has reduced the casting thickness of the M55 oil pump. In a hi-po engine the casting will break off in the neck area.
RBob.
RBob.
theshackle
Mar 5, 2017 06:37 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
