SBC and BBC flywheels the same?
Old Jul 13, 2001 | 07:26 AM
ede's Avatar
ede
i think they are? i'm about to get a BBC for my old car and it doesn't have a flywheel so i want to reuse the one from my 336 SBC on the BBC. thanks
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 13, 2001 | 07:49 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Not normally. Most SB fws are drilled for a 10.5 inch clutch. BBs are 11s. That makes most sb 153 teeth and BBs 168 (I think). Then you have the externally balanced issue with 454s.
Old Jul 13, 2001 | 08:52 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Externally balanced, no. Internally balanced, yes. But the ring size (153 or 168) depends on what the bellhousing can accomodate size wise.
George P. Lara
1984 Z28
2001 SS #0391
SCCA, SCFB, SC3GFB
Old Jul 13, 2001 | 11:50 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
i believe most big blocks and small blocks shared the same flywheels and even starters, excepting the 454 from this rule..
my Dad's '72 402 1/2 ton truck takes the same starter as my '72 350 El Camino did, same PN#
Webmaster: www.IROC-Z.org
Old Jul 17, 2001 | 03:13 AM
87RS402's Avatar
SBC and BBC flywheels are absoultly interchangeable with the exceptions being the 400 SB, 454, and the 502. Those are externally balanced. Starters are a slightly different matter. The simple explanation is don't expect a 327 starter to spin a 454.
Old Jul 17, 2001 | 03:14 AM
Engine: 305TPI
i've read that GM used some gear reduction starters on small blocks..
i want one but they're a small fortune, 150ish bones.. ouch.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
