Piston Rings.
Subscribe
Jul 18, 2001 | 05:41 PM
Hey guys, how hard is it to change the piston rings in a 350? whats invoved...do i need a special tool? whats it called? how much is it!!
Reply 0
Jul 18, 2001 | 06:19 PM
If you dont even know THAT, I wouldn't recommend doing it yourself. You should already knwo that the engine has to come out and it has be to rehoned and pretty much rebuilt.
Anyway it's called a ...watch this... "piston ring compressor" and it's about 10-20 bucks depending on the quality and design.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car !
Reply 0
Jul 18, 2001 | 10:37 PM
ok, not to be mean, but what gives you the right to assume that i dont already know that i need to take the engine out and re-hone it, i basically am rebuilding it, its just my dad says its really hard to re ring it. now personally i dont appreciate being assumed ignorant. now i think you should reconsider what you said and try not being such a **** ...thanks for the input tho!
Reply 0
Subscribe
