88 vs 92 tank & pump
Old Mar 23, 2005 | 08:34 AM
4MULA88's Avatar
Car: 83 T-top T/A, 92 RS
Engine: 1970 LT1,305 TBI
Transmission: Th-400, 700r4
Axle/Gears: 3.42,2.73
Is there a diff between a 88 305tbi firebird gas tank and pump & a 92 305tbi camaro tank & pump,besides the baffels.
Old Mar 23, 2005 | 01:19 PM
4MULA88's Avatar
anyone? The reason I ask is my 88 formula has a brand new pump and the body is shot. The 92 has a good body
Old Mar 24, 2005 | 07:19 AM
4MULA88's Avatar
ttt
Old Mar 24, 2005 | 11:48 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I can tell you from experience learned the hard way that even a good functional tbi pump is junk. If your pulling the tank then spend the extra 100 some odd dollars for a good aftermarket or higher performance GM pump, even if the motor is still stock. While a HV pump could empty your gas tank a dozen times over in an hour, the tbi pump would still be struggling to fill up a shot glass. its really that bad.
As far as the tanks, I dont think either one has all that much baffling and each could substitute for the other. You can tell for sure by pulling the pump assy. and visually inspecting each. Id use the tank thats in better condtion.
Old Mar 25, 2005 | 08:08 AM
4MULA88's Avatar
Thank for the help
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Glowsock
Aug 31, 2015 09:01 PM
Glowsock
Aug 26, 2015 12:28 AM
beachrodder
Aug 25, 2015 08:05 AM
