Who makes AC Delco oxygen sensors?
Old Mar 23, 2005 | 08:41 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
I remember reading on here that several people have recommended AC Delco oxygen sensors over the typical replacements by Bosch, due to Bosch's recent poor quality control. Unfortunately, I can't seem to locate the posts.
I was talking to my friend who works at the auto parts store and he said that AC Delco's oxygen sensors are made by Wells, and Wells is the cheaper (i.e. "lesser") model that he sells, as Bosch is the "premium" choice. He said that AC Delco really doesn't make any of their own stuff anymore.
I was curious if the Delco sensor recommendations were recent or not, and if it is the Wells unit that several people have been suggesting. Can anybody confirm this?
Old Mar 23, 2005 | 11:22 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Dont run anything but AC Delco parts.
Old Mar 23, 2005 | 11:27 AM
rezinn's Avatar
I've used Bosch oxygen sensors on any car that needed a new one and never had a problem. This includes my camaro.
I don't know if wells makes ac delcos sensors now, though.
Old Mar 23, 2005 | 01:14 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
In this thread, I found the following statement from Vader:
Bosch was (and may still be) the O.E.M. supplier to GM for oxygen sensors. If you HAD purchased the AC/Delco sensor, you would have opened the red, white, and blue AC box and found a Bosch sensor inside.
I sorta suspected this, but I question why my parts guy said that Wells makes the current Delco oxygen sensors.
I installed a Bosch sensor in my Camaro about two years ago, and I've clocked less than 6,000 miles on it since then. I believe the less-than-stellar performance is due (in part) to a bad oxygen sensor. Through my datalogger, I'll typically see the sensor feedback voltage just "drop out," or hang on the same number no matter what I'm doing with the accelerator. The BLM counts show an usual tendency towards leanness, as well. I think a new sensor is going to fix this intermittency, and I didn't want to go with another inferior unit.
Old Mar 24, 2005 | 03:43 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Before you blame the sensor, have you done any intake work? Something that required using some sealant? If not specifically marked as being "O2 Safe", that could have messed yours up. Also, if you're running pretty rich they can get carboned up. If that's the case, holding the motor to 3K rpm for 15-20 seconds in neutral will sometimes clean them off. Otherwise, it's replacement time.....
Old Mar 24, 2005 | 04:19 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Thanks for the tips, vernw. This engine has been freshly rebuilt (I've put maybe 20 miles on it), but the oxygen sensor problems have been there even before the rebuild... my drag racing logs show this. At that time, I never used any sealant around the intake, nor do I feel the engine was running all that rich (according to the logs, anyway). I'll have to pull the sensor and see what it looks like, just out of curiosity.
9192camaro
16
Feb 3, 2019 12:21 AM
sailtexas186548
Jan 19, 2016 12:21 PM
g.l.mos
Aug 22, 2015 12:02 AM
perZ
Aug 21, 2015 05:51 PM
beast94
Aug 20, 2015 06:44 AM
