Piston to bore clearance.
Old Jul 20, 2001 | 01:49 AM
PerthZ28's Avatar
Engine builders - what sort of clearance can I get away with? The Haynes manual lists a maximum of 2.7 thou, the Clymer manual lists 1.7 thou max. WTF?
Old Jul 20, 2001 | 07:42 AM
ede's Avatar
ede
my manual list .0017 to .0041 cleareance at the bottom of the piston. a lot will depend on the type of piston you're using and what the make recommends to use.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 21, 2001 | 02:13 AM
PerthZ28's Avatar
I was going to re-use the original cast pistons if they measured-up OK.
Old Jul 21, 2001 | 09:08 AM
ede's Avatar
ede
you shouldn't have any problems reusing the same pistons. you want to be careful when you have a block bored or go to aftermarket pistons.
ICON Motorsports
1st & 3rd
FormulasOnly
Jul 23, 2018 08:47 AM
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
