Oil Presure senser location
Old Mar 26, 2005 | 02:58 AM
84 Restore's Avatar
Car: 1984 Z28 camaro HO Gun metal Gray
Engine: 305,L69 H.O. rebuilt
Hi Guys
In the pic I have a Number 1 and 2 #1 is the electronic oil presure senser. Question is.. Is it in the right location for my motor. I taged it but my instructions were a little vague and 12 months later I don't remember
The #2 is my second question. I have an unaccounted for threaded hole in the intake that I cant figure out what goes there. I am further along with the assembly then in the pic and ready to put motor in but I dont. know what goes in this hole. I dont have a better picture than this at this time but if I need to I can get one. I asked a friend..non third gen and he said cap it but I think thats foolish not knowing what goes there. any help?
Thanks in advance.
Old Mar 26, 2005 | 03:29 AM
84 Restore's Avatar
Lets try this pic again
DUUUUHHHH try this again
Well its not working for some reason my changes to the pic will not come out on transfer but I was able to crop the senser out so you know what i am talking about. The part 2 of thisunknow threaded hole is located on the closest side of the intake (left side) about in the middle but a little towards the back. Sorry I cant help with the location any better. See what you can come up with and thanks
Attached Thumbnails Oil Presure senser location-e-ptl.-allen-z28
Old Mar 26, 2005 | 05:56 AM
ede's Avatar
ede
the hole in the china wall is 1/8 NPT and is for the oil sender to the gauge. the same size hole above the oil filter is for the cut off to the fuel pump.
Old Mar 26, 2005 | 06:03 AM
84 Restore's Avatar
Don't mean to be rude but ...WHAT..... china wall , 1/8 thingy. Is the oil gauge senser in the right place or am I all messed up?
Old Mar 26, 2005 | 06:16 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Maybe the brake booster hooks up to that port on the manifold (assuming it's vacuum)??
Old Mar 26, 2005 | 06:46 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Oil sensor is in right location. On your motor, the cutoff switch and oil pressure sensor both mount to the same fitting where your sensor is, not the one by the oil filter. Can you take another picture and point with a pen or something to the mystery port on the intake?
Old Mar 26, 2005 | 07:23 PM
84 Restore's Avatar
I am at work right now but I will have a pic for you tomorrow.Thanks for the help
Old Mar 26, 2005 | 09:18 PM
84 Restore's Avatar
Ok I found a little better pic and i think I figured out howe to draw on it. I have and arrow pointing to the threaded hole. It is covered with silver tape in pic but its where i have pointed
Ok it didnt work man I suck... if you look on the right side of intake (looking at it ) it is about 5 inches from the black bracket in the the pictiure. hope it helps but I will get a pic tomorrow anyways.
Old Mar 27, 2005 | 11:57 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The oil pressure sensor is in the right place at the rear of the engine. It is the canister on the brass 90* pipe.
Old Mar 27, 2005 | 09:59 PM
84 Restore's Avatar
You all have answered the oil gauge sensor location now I need the mystery threaded hole in the intake questioned answered. I have a new pic of the hole and I am pointing to it. I am hoping that some one can tell me what goes in there or have a pic of the area inwhich i can figure it out with. Thanks again
Old Mar 27, 2005 | 10:48 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
That is a bolthole for a bracket that you have not put on yet/may not need. Blind hole, not overly important. (May be for A/C bracket.)
Old Mar 28, 2005 | 08:05 AM
Guido's Avatar
Car: 2000 Trans Am
I think you missed the carburetor with the kentucky chrome
Hotrodboba400
Dec 10, 2019 07:07 PM
tgp1990
Sep 4, 2015 06:24 AM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
