brought bird out of hibernation...leak detected
Old Mar 26, 2005 | 05:46 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
I just brought out my bird today from storage and I noticed some spots on the floor of the garage. I looked under the hood in the general vicinity and noticed a small drip, as the engine warmed up the drip got a little faster. It appears to be antifreeze. I checked all around the area and it doesn't look like it's leaking from the heads, it looks like it's right by the motor mount. My neighboor said it might be the freeze plug. Does this sound right, and is it pretty difficult to get the replaced??
Old Mar 26, 2005 | 05:50 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
sounds possiable but, I would psi check you cooling system and make sure that is the cause. easy part to get but, can be a bitch to remove.
87v6Bird
Jul 1, 2018 04:12 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
BWilcox
Sep 20, 2015 12:19 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
