Suggestions/Opinions
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I need help making a decision. In the next few weeks I'm putting one of my engines in another car. The car has a full TPI setup with it, just needs a new engine. Should I just drop the engine in with a carb or should I throw the tpi on it since everything for its already there? I can't make up my mind which would be easier. To swap the tpi on all I really need to do swap the intakes (right now it has a proformer rpm) and put in a TPI compatable cam. I guess I'm really just looking for some opinions. Thanks.
Edit: Also does anyone know if all SBC motor mounts are the same? I have a new set I bought for my vette and I'm wondering if there useable on an F-car, thanks again.
Car: 1989 Iroc-Z
Engine: 350ci SBC
Use the TPI.....the dizzy for the car depends on having the computer hooked up. Also TPI is cooler than a carb
The engine mounts will be the same......
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Re: Suggestions/Opinions
Long as you have everytyhing squared away then it's all good. Take pic's to have for reference. Lot's of them.
