Door lock tumblers?
Old Jul 24, 2001 | 10:37 PM
One Eyed Jack's Avatar
Door lock tumblers?
Yeah don't tell anyone but *sometimes* my door opens with any key. How much are new tumblers and how hard are they to install?
1992 Pontiac Firebird
- 305ci V8 TBI / Automatic Trans / Loaded
- MODS: Edelbrock 14x3 Open Element Air Cleaner, Dual outlet exhaust
1985 Chevy Z28
- 350ci V8 TPI / Automatic Trans / Paid $200 for it
- In the process of restoration!
Old Jul 24, 2001 | 11:50 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Autozone carries door locks for around $12-$15 (I believe) for the pair. Replacing the pins in your locks isn't exactly a DIY kind of job unless you have the tools.
The mind is like a parachute, it only works when its open
Old Jul 25, 2001 | 12:30 AM
mcconahay37's Avatar
You can get a set of new locks at most parts stores for cheap. It's not too hard too replace them. You just have to contort your arm in some weird ways.
82 Camaro:
350
Erson cam, ported heads,Comp Cams 1.6:1 rocker arms
Edelbrock Performer RPM intake, Holley 600
Crane Hi-6 ignition, Accel supercoil
TH350 tranny with 2500 stall.
Eibach Pro Kit
SLP 1 3/4" headers
[This message has been edited by mcconahay37 (edited July 24, 2001).]
Old Jul 25, 2001 | 05:56 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes, its definatly not someting you do in your driveway. The tumblers usually come in a kit, along w/ other items you should replace like the tumbler cover, tumbler springs, and lock cover. Try some powered graphite first.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 25, 2001 | 11:23 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Where do you find "powered" graphite GM?
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
my86bird
Oct 23, 2015 12:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
SG91camaro
Sep 5, 2015 10:27 PM
