BROWN COOLANT
Old Jul 26, 2001 | 07:26 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
BROWN COOLANT
My water pump is making some noise so i check the rad, its brown, what gives. it doesnt really over heat 220-230
1986 TPI 305 TRANS AM
Old Jul 26, 2001 | 07:30 PM
82camaro's Avatar
Car: 82 camaro SC
Have you been changing the coolant every 30000 miles. Checking it every oil change? Rust.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jul 26, 2001 | 07:46 PM
TOM305T/A's Avatar
changed the water pump, stat, rad & hoses around 15k ago
Old Jul 26, 2001 | 10:29 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
change the coolant, flush it well, and keep an eye on it. drain and refill the radiator a couple times before you flush until the water comes out clean. Remove and flush the coolant jug. Stuff like that. Sounds like rust to me unless someone's been adding orange dexcool coolant, a no-no to mix with green coolant!
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
