overheating SBC400
Old Jul 27, 2001 | 04:46 PM
JSweet's Avatar
overheating SBC400
I have a 85T/A that i recently drop a SBC400
in and I am having problems with the motor running too hot.It tends to want to hover around the 220* mark but rises when I sit still for a while. I have flushed the system,
set the timing at +6*,changed thermostats 160 then 195,added electric fans that now run all the time except at startup. the carb seems to be a bit rich not lean. The only problem I can see is the distance from the header crossover to the oil pan. If anyone else has this combo, have you had problems?
85 T/A sbc400,edelbrock tes headers,061 heads,3in. exhaust,flow master,k&n air filter,holley 700dp,weiand stealth intake,comp cams 270 cam
Old Jul 27, 2001 | 05:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Better than stock water pump, high-flow thermostat, 70% water to AF coolant ratio, some Red Line Water Wetter...
www.stewartcomponents.com
I had a 400 for many years in my 83 Z28, with the stock cooling system, with minimal problems. I had to put my original L69 (well, sort of) back into the car recently to pass California emissions inspection, but the 400 always stayed at a reasonable temp even when I was living in a much hotter part of the country. I had a Stewart Stage 2 water pump on my car for the last couple of years the 400 was in it.
ICON Motorsports
Old Jul 27, 2001 | 07:13 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
do you have the air deflector in place in front? U got steam holes?
Old Jul 27, 2001 | 08:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes and yes. Wouldn't leave home without them.
ICON Motorsports
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
