Base ignition timing..still probs
Old Apr 4, 2005 | 09:53 PM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
Ok, I posted a topic awhile back about base timing the motor... I dont have any problem with timing just finding the right wire on the car thats the EST bypass. My car is any an 84 T/A 305 w/the q jet and the label on the car says to disconnect the 4 wire connector but the only 4 wire connector I see is the dizzy it's self and the car wont stay running with it removed. The peice of crap Haynes manaul says there is a one wire connector usually near the EVAP case but i swear I have looked freaking every where and I cannot find it. The only other 4wire connector I see if near the power brake booster. Is there any other way to disable the EST so I can get this motor timed?
Old Apr 5, 2005 | 09:01 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I thought I'd bump your post for you...pretty sure some know the answer...might try a new topic How to set base timing with CCC"?
Old Apr 5, 2005 | 11:18 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
What your doing is correct. You should disconnect the 4 wire connector at the dist. Its only with the later cars that youll have a special est connector since the ecm wont fire the injectors without any reference pulse (need 4 wire connector hooked up).
Old Apr 6, 2005 | 03:45 PM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
Thats what I figured to, but the motor wont stay running long enough for me to get a timing light on it.
Old Apr 6, 2005 | 04:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Then turn the idle speed up to a point where it will stay running; set the timing; and then return the idle screw to where it was when you started, and re-adjust it from there.
88SS6SPEED
Nov 11, 2015 07:05 AM
BOOT77
Oct 17, 2015 12:09 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
Jlanz55
Sep 6, 2015 02:35 PM
