uneven idle
Old Apr 5, 2005 | 12:42 AM
96Iroc's Avatar
Car: 1986 Iroc
Engine: 355, aluminum heads
Transmission: Built 700r4
Axle/Gears: 3.42s
uneven idle
I've been trying every bit of information I can find to stabilize the idle on my '86 305 Iroc tpi. When it first starts (cold) it idles almost what seems right but give it a rev and it idles much higher. Then when I shut it off and then restart it anytime its warm, the idle goes up to about 1700-1800 rpms. I have replaced the Iac motor, cleaned the passages, set tps voltage (.54) checked for vacuum leaks, checked for codes,(getting a code 32 EGR). Testing indicates EGR and solenoid to be OK. I am at a complete loss for a solution. Anybody have a similar problem/fix for this?????
Help.
Old Apr 6, 2005 | 02:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm not TPI expert, but I'd guess from your description that the EGR is not operating consistently.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
