?? for Mini Ram owners
Old Jul 28, 2001 | 04:49 PM
FasNuf91's Avatar
I am about to drop my new motor in but i am not sure what needs to hook up to my mini ram..... There are two coolant plugs towards the front of the manifold and four vaccum fittings on the sides of the intake... what do you guys have running to all of this stuff.... my main concern is the coolant holes. I got a sensor going in one of them now but what about the other one.... I heard something about running a line from that into the top of the water pump... if so why?
thanks
91 Z28 350CID, miniram, afr195s, took out all a/c, heater, smog, and cruise control, 700R4, fast chips, map sensor
Old Jul 29, 2001 | 02:56 AM
Omar's Avatar
Sorry this is not a tech answer, but what part of SD are you in?
I would love to check out your new mini-ram setup sometime. Even lend an extra hand if needed.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jul 30, 2001 | 12:38 AM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
I put a fitting there and ran a hose to the heater valve. The factory routing would have just run from there through the throttle body and then to the heater valve.
'89 Formula 383 TPI
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
indygene
Sep 26, 2015 11:21 AM
09ave
Sep 7, 2015 06:03 PM
