More aftermarket fuel pressure reg. questions
Old Jul 30, 2001 | 05:45 PM
Enkil's Avatar
Well, it's more a do-it-yourself job.. The one where you take the pressure regulator, drill out the weld spot, and cut a groove in the threaded rod so you can adjust it. My question is, what decreases fuel pressure, and what raises it? Does a clockwise motion decrease, and counterclockwise increase? I thought I knew, but I can't get my car running right, and this might be why
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jul 30, 2001 | 05:52 PM
KiDKiD911's Avatar
Clockwise turns the pressure up, counterclockwise turns the pressure down. Do you have a gauge? I'd recommend a gauge if you've lost your spot Are you getting any o2 lean/rich codes? If not you shouldn't be in any danger area...
Corey Turner - Toledo, OH
91 9C1 - "Project Potent Rodent"
www.geocities.com/kidkid911/index.htm
-350ci / Ported Vortec's - 10:1 Compression
-Crane '509 lift hyd. roller cam / 1.5" Roller Rockers
-Ported Holley 670cfm TBI on a Edelbrock Multipoint EFI System / Paxton AFPR
-Heddman Full-Length Headers piped to Dynomax 2.5" True Duals / DM Turbo Mufflers
-K&N Dual Air Inlets running to Ram Air II Hood
-MSD 6A Ignition Controller / MSD Blaster 3 Coil / Accel wires-cap-rotor
-Ed Wright Fastchip in a 7747 ECM
-Flex-a-lite 210 Electric Fans - 160 Thermostat
-700R4 w/ a B&M Shift Kit
-3.43 Posi-Rear
-Ram Air II Hood, Custom spoiler
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
