What's the difference between?
Old Apr 10, 2005 | 12:52 AM
Genesis98's Avatar
Car: 88 Camaro SC
Engine: 2.8 ->305->350
A 2 bolt main motor and 4 bolt main motor? and could you also list pro's and cons?
Old Apr 10, 2005 | 01:00 AM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
2 bolt main = 2 bolts in main cap
4 bolt main = 4 bolts in main cap
4 bolt mains are rumored to be stronger.
Old Apr 10, 2005 | 01:03 AM
rokn91rs's Avatar
a sbc has 5 mains on a 2 bolt main block all the mains have 2 bolts. on a 4 bolt main block the 3 middle mains have 4 bolts and the outer 2 have 2 bolts. a 4 bolt main block keeps the mains from moving around. if your not making over 500 horse or turning over 7000 rpm it really doesn't matter. a 2 bolt main will work just fine.
Old Apr 10, 2005 | 06:29 AM
ede's Avatar
ede
if you ever wanted you couldn't use splayed caps on a factory 4 bolt block
Old Apr 10, 2005 | 12:48 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
It's just insurance to have a strong motor, like forged pistons or crank.
but like rokn91rs mentioned, it's not usually that important, in spite of the fact that most hot rodders will only use it because of it's rumoured higher strength. unless you rev it really high, or make tons of power, then it's not that important.
and remember, you can machine a 2 bolt main for 4 bolt splayed end caps, which are even stronger. you can't do that with a 4 bolt main.... kinda a catch 22 I guess....
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
