Big, bad miss (a little long)
Old Apr 10, 2005 | 05:39 PM
Eric's Avatar
Car: 87 GTA
Hey guys. I have been out of circulation for a while. Before putting my GTA away for storage it was running like crap. I tried all kinds of things to fix or diagnose the issue, but to no avail. I just pulled it out of storage and I am back to troubleshooting. Here is the deal...
Very rich, super stinky exhaust (no black smoke that I can notice though). Under load, it surges, bucks, farts, stutters and misses. If I load it up just a bit (foot on gas/brake) I can feel a major miss and stumble, then it smoothes a bit, then misses again, and so on.
Here is where I am at:
- NO CODES
- scanned with computer - everything reports completely normal as far the computer is concerned
- new plugs (AC Delco)
- relatively new wires (Accel 8mm)
- new cap/rotor
- new distributor pickup coil
- swapped ignition coil
- had ignition module tested
- swapped EGR valve
- new EGR solenoid
I think that about covers it. I truly don't know what else to do, short of taking it to the shop. If anyone can shed some light on something I might have overlooked that would be awesome. Please, toss some suggestions out!
Old Apr 10, 2005 | 08:32 PM
Vader's Avatar
Sounds like you may have one or more dead holes (unburned fuel in exhaust), one or more really bad injectors (leaking straight through), or no spark/ poorly timed spark on one or more cylinders (look for crossed secondary wiring). If you have done the "5-7 swap", those two cylinders will be effectively dead. Run the firing order again to be certain.
Frozer!!!
Jan 19, 2024 04:55 PM
beast94
Aug 20, 2015 06:44 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
