Relocated/protected fuel line with header install?
Old Aug 1, 2001 | 11:56 AM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Finishing up my 350 swap and when I bolted
the Edelbrock headers in place the fuel line
(passenger side) comes very close to the
headers. Runs about 3-4 inches away for the
whole length of the engine and down to about
3/4 of an inch down by the collector. Anyone
have any problems with this or tried to
protect the fuel line. Headers are jet-hot
coated but I don't know how much that will help.
Tom K.
84 Z-28 M5 305 L69 HO
pulleys,coil,3:73(stock)
Jet chip, fan switch,
Al dshaft,1.6 rockers,
LCAs and brackets,BFG DRs
14.20 @ 96.74 2.02 60ft
Old Aug 1, 2001 | 01:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
BTDT...
I cut my fuel line, flared it, and made a new section to make that portion of the run pass as far from the headers as possible. If you run it right you can get it about 2" from the headers, which is about as far as anything down there will ever be from them. It's easier if you pop the evaporator housing off, it doesn't have to come all the way out of the car, which only takes a couple of minutes... I went to the junkyard to get one, got there at 4:55, found a car, and had the housing which is now in my car sitting on their counter by their 5:00 closing time.
ICON Motorsports
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Firechicken86
Aug 12, 2015 10:07 PM
