Anti-Freeze pouring through A/C vents?!?!?!
Old Jul 31, 2000 | 05:16 PM
KamaroZ350's Avatar
Car: 2008 Jeep Wrangler Unlimited
This happend to my friends 1989 or so GTA, he said he was driving it and as he pulled into his driveway, and all of a sudden Anti-Freeze starting comming through his vents and it was about to run hot!
Now i have never heard, seen, or thought of this was possible.
How in the world did this happen, at 1st i thought he was jokeing, when i got to his house, anti-freeze was all over the place.
1991 Z28 Camaro L98
5.7 T.P.I. (350)
http://www.bright.net/~rwig/BandetZ28.jpg
http://www.bright.net/~rwig/BandetZ28-2.jpg
Old Jul 31, 2000 | 06:16 PM
The Man's Avatar
Sounds like the heater core busted. It's not real fun replacing one either.
Old Jul 31, 2000 | 06:23 PM
z/28cwby's Avatar
I had the same problem a few weeks ago after swapping in my 350. When I put the heater hoses on I pushed them all the way against the firewall. I ddin't get one tight enough and instead of dripping down to the ground it leaked inside of the A/C ducting. Backed the hoses off abit and tightened them down good. Haven't happened since. Wife was a bit upset. She was driving when it leaked in.
1984 Z/28
GoodWrench 350, Edlebrock Performer intake, MSD 6AL Super HEI kit, Crane CompuCam 2040, Edelbrock headers, Catco cat, Flowmaster aftercat, K&N, Custom 700R4, B&M Megashifter, Eibach springs, KYB GR-2 struts/shocks, Jegster adj LCA's, Lakewood adj panhard bar, BFG Comp T/A's, 160* stat, AutoMeter Pro-Comp COOLANT GUAGE.
Old Jul 31, 2000 | 08:00 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
yup yup.. heater core.. not a fun fix, pretty much gotta remove the whole dash to get to it.. anyway, if you live in a warm area and can go without heat, you could always get a small section of 5/8 (usually) tubing and just put it between the hoses running to the heater core and bypass it, although you wont have no heat..
Old Jul 31, 2000 | 09:43 PM
KamaroZ350's Avatar
I cant speak for him, but for myself, i dont use my A/C unless my moms in the car and nags me about being hot. And i CANT go without heat, i cant stand freezing my a$$ off.
Old Jul 31, 2000 | 09:46 PM
KamaroZ350's Avatar
I removed my dash today, and it took less than 5 minutes, are you talking about the Whole front part also?
1991 Z28 Camaro L98
5.7 T.P.I. (350)
Old Jul 31, 2000 | 11:02 PM
fredo92's Avatar
Car: 92 Camaro RS
I got to do a heater core on my camaro and basically removed the entire dash, console, and passenger seat to get to the stupid leaking piece of sh*t heater core. Good luck with it man.
Old Jul 31, 2000 | 11:30 PM
CamaroZ_85's Avatar
i did my heater core by removing 2 panels, took about 15 minutes.....if you have a panel that covers the underside of the dash on the pasenger side, remove it. you'll see a black box there...remove the 3 (i think it's three) screws that hold it in....one on the bottom left, one on the top right, and i think the other was on the bottom, in the middle. pop that panel off and the heater core is right there...you just need to remove the plastic bracket that holds it in place. there are 2 screws on the left side of it, way back there...I got them w/ a 1/4 nut driver and a few extensions. it's a little tough because of the center console but you can work your hands into the spot if they're small like mine. once you get those 2 screws out i think there are 1 or 2 on the right side...then the bracket will just pop out and the heater core just pulls right out (as long as you removed the hoses) the hardest part was getting the 2 screws back in the bracket on the left side, that took some patience and manuvering
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
Old Aug 2, 2001 | 12:02 PM
simon's Avatar
Do your self a favor and check into what Z28cwby said. If those hoses are loose or cracked, the fluid will leak down into the box, out the lower vents and onto your floor mats. If thats not the case then, your heater core probably ruptured. Its not a hard fix, just time consuming. It takes a lot longer than 15 min. at least in my 89 RS it did. The shop was going to charge me $400 just for labor, I laughed in their face and did it myself in about 2-3 hours. I have heard that the cores made by GDI (Go-Dan Industries) are one of the best units to get. You don't have to remove the whole dash, just drop the steering column and pull the pass. side of the dash far enough to get at the heater box bolts. I think there is a
Tech Article on this.
Old Oct 20, 2011 | 04:30 AM
KamaroZ350's Avatar
Re: Anti-Freeze pouring through A/C vents?!?!?!
test
Old Oct 20, 2011 | 07:05 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
yes your profile still works. Still have that 4thgen camaro abortion?
Old Dec 27, 2011 | 11:39 AM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
15 min? Man, there must have been some good stuff floating around back in 2000. Plan on 4hrs to be on the safe side but 3 should do it. Loosening the dash up and pulling it out about an inch helps a lot. But then my console and radio pod is out due to changing carpet.
Old Dec 27, 2011 | 02:16 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
while 15 minutes is a bit of a record, you can usually do one on these car in under an hour. removing the dash does make things easier, but not necessary. you can reach all of the heater box bolts and remove the cover without dropping the dash. 1/4" ratchet, a swivel joint, and a couple extensions should make the job pretty easy
Old Dec 27, 2011 | 03:10 PM
BLT's Avatar
BLT
This happened to me once... except it didn't pour out. It started as a weird fog on the inside of the windows
Old Dec 27, 2011 | 05:37 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
I can see it if you have done it before. But my hands are too big to get in there without loosening the dash. I could see what needed to be done but couldn't do anything but cuss it till I loosened the dash.
And I won't even talk about the running around getting a core and wasting three hours and still don't have one.
Old Dec 27, 2011 | 05:56 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I can do them in 30-60mins and thats having a beer or 5. Not hard to do at all.
Old Dec 27, 2011 | 06:07 PM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
I can do one in 30-60 beers. Not hard to do at all.
Old Dec 27, 2011 | 11:03 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
I just replaced the core in my '86 and did not move/remove the dash. Removed the top dash pad to get my hand on the top nut but found I really didn't need to do even that. I got to all the nuts from underneath. Even put the top one back in!
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
