Cam spec question
Old Apr 13, 2005 | 08:34 PM
camarodude91's Avatar
Cam spec question
I tore apart my 350 this weekend to replace the cam heads and intake. The motor ran pretty strong and I was told it had been rebuilt recently when i bought it. Well when I pulled the cam it was a crane cam. It said Crane Fireball 290h. i search the internet and crane's website but didn't find anything. Can someone tell me what the specs are?
Old Apr 13, 2005 | 08:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
http://cranecams.com/?show=browsePar...78&lvl=2&prt=5
Old Apr 15, 2005 | 06:00 PM
thank you i guess i should have looked harder. Could I reuse this cam with new lifters or not?
Old Apr 15, 2005 | 06:05 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
You can reuse roller lifters if they're not collapsed, but never flat tappet lifters ever.
Old Apr 15, 2005 | 06:10 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
You should be able to re-use it with new lifters (I've done it before). You will have to follow standard break-in procedures though. As Token said, don't re-use the old lifters, after all, it is a flat tappet cam.
Old Apr 15, 2005 | 06:15 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
But for a set of nice lifters from Comp Cams, $60 is cheap insurance against a wiped lobe or abnormal lobe wear...
Old Apr 15, 2005 | 06:21 PM
Zed'er's Avatar
Car: 84 Z28HO
Quote "Could I reuse this CAM with new lifters or not?"
He wants to use new lifters with the old cam, not reuse the old lifters.
Old Apr 16, 2005 | 01:38 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Old Apr 16, 2005 | 10:49 PM
I know not to ever reuse lifters I just wasn't sure if the same applied to the cam itself.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
80s Poncho
Aug 19, 2015 06:45 PM
redmaroz
Aug 16, 2015 11:40 PM
