106 0R 110
Old Aug 2, 2001 | 06:46 PM
91TA's Avatar
106 0R 110
Just wanted to know which is better. To install the cam @ 106 centerline or @ 110 centerline
Old Aug 2, 2001 | 06:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
better for what?
ICON Motorsports
Old Aug 2, 2001 | 07:06 PM
91TA's Avatar
The specs on my cam are for a cam installed @ 106 intake centerline. If I understand this thing right then that means I should install my cam @ 4 degrees advance instead of straight up (0 degrees)Is that right or wrong? Can someone shed some light on this without getting to difficult.
Old Aug 2, 2001 | 07:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Advancing the cam increases low end torque at the expense of high end RPMs. Retarding the cam does the opposite.
OEM's often (at least, used to) advance the cam to allow for cam chain stretch over time. This put the cam more in its intended operating range as the engine got older.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
JPrevost
Oct 2, 2014 11:38 AM
Wiggles
Apr 12, 2011 03:47 PM
tricky1
Oct 29, 2010 10:59 PM
sicktwin
Jul 4, 2010 10:51 AM
R3500
Oct 30, 2008 10:24 AM
