Disconnecting AC???
Car: 99 Formula
Axle/Gears: 342
Disconnecting AC???
My AC unit is already out since I got the car. But I want to clean up the clutter that is attached to the firewall on the passenger side. I was planning on taking the 2 boxes on the firewall and getting a blockoff plate from a junkyard off of a non AC Camaro. There are a bunch of wires that are disconnected but there are some that look like sensors,they are still plugged in, I am no longer running my ECM so is there any sensor that I unplug that will hurt anything.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
most likely not, but there are a few that go to the gauges and such. if you unplug something you shouldn't you'll know it pretty quickly.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 99 Formula
Axle/Gears: 342
OK, I got off the top plate and filter, but can't figure out how to get the screws that are holding the bottom of the housing. How many are there, with my headers there it is real cramped. Will I have to get under the car.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
