New 383 being assembled :D
Old Apr 16, 2005 | 01:30 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Just got it back today .
Attached Thumbnails New 383 being assembled :D-new-block.jpg
Old Apr 16, 2005 | 01:32 AM
pasky's Avatar
Eagle 5130 5.7 SIR Bushed rods + -3.4cc forged sealed power pistons
Attached Thumbnails New 383 being assembled :D-rods_pistons.jpg
Old Apr 16, 2005 | 01:34 AM
pasky's Avatar
Piston close up.
Attached Thumbnails New 383 being assembled :D-piston-close-up.jpg
Old Apr 16, 2005 | 01:39 AM
pasky's Avatar
6.3 liter 383 CI 95 LT1 block
GOnna have a 11.54:1 static compression and
forgot the dynamic but it was 8.xx:1
cam is:
230/244 .544/.574 (1.6 rockers) on a 112 LSA
Ported heads flowing:
.100 72/54
.200 138/110
.300 195/144
.400 245/187
.500 262/202
.600 262/208
and 42# injectors
Im looking to put down 420rwhp and about 480-500 at the crank.
Gonna be one hell of a ride when I get it done over these next weeks, will keep this updated .
Old Apr 16, 2005 | 02:01 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What ported heads are those?
Old Apr 16, 2005 | 02:25 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
That looks like an LT1 block to me, so I'd guess either LT1 or LT4 heads are going on it...
Old Apr 16, 2005 | 02:47 AM
pasky's Avatar
https://www.thirdgen.org/techbb2/sho...ght=ported+lt1
Old Apr 16, 2005 | 08:48 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Be careful with those rods, I had a set and they were so out of round from the factory due to a problem eagle was having. They were not torqueing them to spec when aligning. I ended up returning them and eagle set me a net set direct and they were still bad. I emailed them and they sent me a set of H beams instead for the same price.
Old Apr 16, 2005 | 09:14 AM
StealthElephant's Avatar
Car: 87' Iroc
Nice healthy looking cam there, looks like that things gonna be a lion on the street, can't wait to see the finished product.
Old Apr 16, 2005 | 11:29 AM
pasky's Avatar
The bearings seem to be sitting fine on these . I have two on the crank right now and it looks good to me. Thanks for the heads up though.
Old Apr 16, 2005 | 05:37 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I'd measure them to be for sure...
Old Apr 17, 2005 | 02:11 AM
pasky's Avatar
*** Update ***
Slowly but surely im getting it done. Going to pull the blown lt1 out of the car tomorrow and start swapping things over (timing chain, cam, headers, intake, etc...).
Pics of the new shortblock and my 1991 RS:
http://community.webshots.com/user/pasky13
Old Apr 17, 2005 | 10:38 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Should get pretty close to that 420 RWHP number you are looking for... I would guess closer to 400-410 than 420 though.... The heads appear to be your weak point but then again the cam is matched fairly well to the head's flow... Should be a nice fairly mild 383 with good street manners.
Old Apr 19, 2005 | 11:56 AM
Parrydise7's Avatar
The next time you should probably think about spending some serious money on an engine.
Old Apr 19, 2005 | 12:20 PM
pasky's Avatar
Im not followin you....
Old Apr 19, 2005 | 12:50 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
I'm thinking it was a joke. Nice to see another 383 going together. I wish I would have gotten my pistons coated. Too late now though.. Can't wait to see it together.
Old Apr 19, 2005 | 01:42 PM
Parrydise7's Avatar
It was a joke. Not a very good one, but a joke...
Old Apr 19, 2005 | 02:28 PM
Matt87GTA's Avatar
Well the reason nobody got it is because he isn't spending that much.... Definately a lot less than I did!!!!!...lol.
Old Apr 19, 2005 | 02:31 PM
pasky's Avatar
about 1900 total for the rotating assembly and machine work.
Old Apr 19, 2005 | 02:36 PM
Rembrandt's Avatar
How did you come up with a dynamic compression number?
Are we thinking of the same thing?
Dynamic compression doesn't have a number, it is transient. Transient=dynamic.
For each difference in volumetric efficiency throughout the RPM range for a given throttle position, and even for a given cylinder since they won't breathe equally, there is a different dynamic compression.
If 100% volumetric efficiency would be the static compression, what would your dynamic compression be?
Peak volumetric efficiency x static compression ???
Or some average?
Either you don't know what that means or you have a special sense of the word.
Old Apr 19, 2005 | 02:58 PM
pasky's Avatar
Or some average?
Dynamic meaning the compression ratio after the pressure is bled off from the came lobes opening the valves. The more overlap on the cam, the more compression you can run without running into detonation.
Example:
http://www.wallaceracing.com/dynamic-cr.php
Now im not sure on the stock head gasket bore thickness so I did two calculations
4.030 bore
0.039 headgasket thickness
4.125 headgasket bore (also did 4.025, not sure the actual number)
3.750 stroke
-3.4cc pistons
5.7" rods
58cc combustion chambers
0.023 piston deck
4.125 headgasket bore gave me 11.48:1 static
4.025 headgasket bore gave me 11.54:1 static
Cam card for my cam:
http://www.compcams.com/Technical/Se...umber=07-306-8
intake valve closes 73* ABDC
With both calcuations I figured:
4.125 headgasket bore size @ 0 ft.: 8.57:1 dynamic ratio
4.025 headgasket bore size @ 0 ft: 8.62:1 dynamic ratio
I was told by my engine builder you can usualy move a decimal point over to the right on the dynamic ratio and that would be the minimum octane to run.
I.E.:
8.57:1 = 85.7 octane minimum necessary
Are we on the same page?
*** Edit ***
Ahhh crud, just noticed the 73* ABDC is for .006 lift.
Gotta find the damn spec .050 or find a calculator that uses .006.
Old Apr 19, 2005 | 02:59 PM
Parrydise7's Avatar
Dayum! (This is intended to be, and is, an expression of approval and admiration).
Old Apr 19, 2005 | 03:16 PM
pasky's Avatar
This oughtta be fun, just called comp and its 43* ABDC at 0.50
10.53:1 dynamic. Weee race gas.
Actually, I think im doing something wrong =/. I know of two people running higher compression than myself and getting away on pump gas (93 octane here).
Old Apr 19, 2005 | 04:08 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
hey pasky i'll take one too.
Old Apr 20, 2005 | 08:15 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
hey Pasky,
This site has some good stuff on DC. Download their VB program and it works like a charm.
Dynamic Comp.
hopefully it works...
Old Apr 20, 2005 | 11:28 AM
pasky's Avatar
Cool thanks, figured I was doing everything correctly because you do not calculate at 0.050, by then their is pressure already being bled off since the valve is opened. My original calculations were correct.
Old Apr 20, 2005 | 02:21 PM
Car: 1986 Iroc
Engine: Afr 408
Yea, you take advertised numbers. hahaha, a 10.5 DCR would be out of control! With an LT1, 8.5 is liveable, use some 92-94 and it should make some sweet power.
Good luck!
Old Apr 20, 2005 | 06:01 PM
Rembrandt's Avatar
I'll be danged.
That makes sense.
Old Apr 21, 2005 | 12:02 AM
pasky's Avatar
Alright then .
Old Apr 21, 2005 | 12:12 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Alright then .
How many folks think you are Muslem cause they think you are from Packistain. "PACKY"
You dirty packy!
But then the same folks might be Indian from India and wonder WTF you are talking about.
The packies might know what you are talking about.
Old Apr 21, 2005 | 12:17 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Um WTF
Old Apr 21, 2005 | 12:32 AM
Engine: SBC, LS-x
Um WTF
You wouldn't understand. Too upright and stiff. The Mechanical Excuse you have in what ever your job is has nothing to do with SBC's. Us mere motals would never understand your pure brain power.
Old Apr 21, 2005 | 12:24 PM
pasky's Avatar
Oooooooookay...
Old Apr 22, 2005 | 01:16 AM
Matt87GTA's Avatar
I'm guessing there is some drama that I missed somewhere here between ya'll????
Because there is definately no tech involved in those last few replies....
Old Apr 22, 2005 | 02:30 AM
pasky's Avatar
Uhhh, none that I know of. Thought it was just a bad joke.
Old May 8, 2005 | 10:07 PM
pasky's Avatar
Valve Train is done. I had a set back of about a week because my rods were hitting the cam with the added stroke so had to take it back to the machine shop to re-balance and clear them.
More photos added of the long block:
http://community.webshots.com/album/323874290BmlIfb
Shooting to drop this in this Thursday/Friday. I hope .
Old May 9, 2005 | 01:47 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
FWIW, you are doing something wrong.
Using the calculator that Thomas Aquinas posted you'll have a threoretical dynamic compression of 9.34. You'll be pushing the limits, but it may be doable.
Old May 9, 2005 | 03:33 AM
pasky's Avatar
Im still getting 8.62:1, like I said, know a couple of guys here running 12:1 static on pump gas.
Old May 9, 2005 | 08:01 AM
Car: 1986 Iroc
Engine: Afr 408
Pasky, how much did you have to clearance the rods? What is the clearance now? 0.050" ? Did you go with a small base circle cam? Also, do you have a pic of one of the rods with the grinding?
The engine looks like its coming along, do you have plans for dyno tuning or a custom chip?
Old May 9, 2005 | 11:09 AM
pasky's Avatar
Yup, rods now have 0.050 clearance between the rods and the cams. Sorry no pics of the clearance it was very little near the rod bolts. Believe it was the #2 and #6 that hit.
Old May 9, 2005 | 12:45 PM
Car: 1986 Iroc
Engine: Afr 408
Did you use a small base circle cam?
Old May 9, 2005 | 02:02 PM
  #42
pasky's Avatar
Oh, nope, regular size. If I did, it would have cleared just fine.
Old May 10, 2005 | 06:55 AM
  #43
Car: 1986 Iroc
Engine: Afr 408
Cool, thanks, I'm going to be building my first 383 in the next couple weeks and have been reading up on clearance issues with the rotating assembly. My main concern is the cam and rod clearance. I've been debating on whether or not to get a small base circle, but I should be able to get by with stock size with my rods.
Old May 10, 2005 | 09:06 AM
  #44
WhiteLightnin83's Avatar
Car: 83 Z28
Engine: Mild 383 Stroker
Transmission: B&M TH400 with shift kit
Axle/Gears: 3.73 Limited Slip
ok i got a few questions for you 383 specialists since i just built this one and i have no idea what i'm doing exactly! well here is a bit of what i have and then i'll ask the questions. i have an eagle 3.75" stroke crank with KB flat-top -7cc dished pistons that are rated at a static compression of 10.9:1 with 64cc heads. the block is zero decked and bored to 4.030". hydraulic crane cam with 234*/244* and .488/.510 lift. the heads are edelbrock aluminum rpm heads. 64cc chambers with 2.02/1.6. weiand intake. hooker long tubes. edelbrock 750 cfm. i think thats about it. anyways what do you think i should run for timing on this thing? i'm gonna put it on the light tonight and i'm also wondering what plugs i should get. i bought a set of platinum 2s and my friend said they are junk so i'm wondering what your imput is on these and if i should get new ones which ones should i get? thanks in advance!
Dustin
Old May 10, 2005 | 12:23 PM
  #45
Matt87GTA's Avatar
Run standard copper plugs with a .035" gap and one heat range colder than stock (not sure what style plug those heads use). I use AC Delco if they are available but have also had good results with Autolites. Platinum plugs are for cars you don't want to change the plugs for 100,000 miles but don't care about performance (platinum is harder than copper and thusly lasts longer, but it is also is poorer conductor of electricity and is more expensive).
I would say timing should all be in by about 3200RPM and be somewhere near 36-ish degrees total but you really need to play with it some and find out what your engine likes as they are all a little different. Get it on a chassis dyno and play with different advances and total timing amounts and go from there...
Old May 11, 2005 | 01:53 PM
  #46
Car: 83 Z28
awesome, thanks a lot... guess i'll just throw the platinum two's in my little beater car or something and get some ac delco's... what is 36* overall? on the light i have it set to about 15ish... is that too advanced?
Old May 11, 2005 | 03:04 PM
  #47
Matt87GTA's Avatar
Well you have to look at your distributor settings and add whatever the total advance is to the base setting (15* in your case) to get your total advance. However, IMO, the ideal way to set timing with a mechanical advance system is to have an adjustable light that you can dial whatever total advance you want into it. With the light set, you have an assistant rev the car up past the RPM where full advance is acheived and adjust it from there. With the light dialed in to 36* you would actually set it to 0 on the tab at high RPM and that way you would know that you have exactly 36* of total timing. Otherwise there is a chance that it could be slightly off. But doing it your way and setting the base and then taking into account the advance amount will get the job done as well and will be pretty accurate.
What kind of distributor do you have in it and what kind of advance curve setup is in it?
Old May 11, 2005 | 05:29 PM
  #48
Car: 83 Z28
hmmm... well all i know about the distributor is that ist an accel supercoil HEI.... does part number 14007 or something like that sound right? i dunno, maybe that number is coming out of my *** but i dunno, its in my head for some reason.... or something relatively close to it...
Old May 12, 2005 | 02:34 PM
  #49
Matt87GTA's Avatar
So it's a stock HEI distributor, non-computer controlled?
Old May 12, 2005 | 02:37 PM
  #50
Car: 83 Z28
correct... i like computers, and i love cars.... i just don't like computers in cars!
