Ignition questions
Old Apr 17, 2005 | 01:21 PM
devilfish's Avatar
Ignition questions
My car wount start.
I got fuelpressure, and the injectors do open ( fuel on spark plugs ).
Is there some way I can crank the engine ( test for sparks ), and NOT flooding the engine with fuel? Is disconect the fuelpump enough?
And can I use a timinglight on no1 spark wire to se if I got spark? Or must I take out the sparkplug and hold it against the metal fram and watch for spark?
Old Apr 17, 2005 | 02:11 PM
Vader's Avatar
You can remove the injector fuses from the fuse panel in the passenger compartment. IIRC, they are marked INJ1 and INJ2.
Old Apr 17, 2005 | 02:16 PM
devilfish's Avatar
Thanks..
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
