Is this okay???
Is this okay???
While back I replaced dist o ring, I noticed that the pick up coil had several cracks on the magnet, also had a bit of rust on the steel wheel. Could that be my hesitation problem that I get ones in a while?
Thanks in advance.
'91 Camaro 3.1 t-tops 44k original.
'98 GMC Sonoma excab 4.3 auto 35k.
Thanks in advance.
Car: 4
Engine: 6
Transmission: 5
Rust = no problem
Cracks = very very bad
Consider yourself lucky that it still runs, and that the worst problem is hesitation. It would be a good idea to take care of that ASAP before you get a nasty surprise.
ICON Motorsports
ICON Motorsports
Problem solved
The pick coil if ok.
The problem was that when it rained, water was getting on the distributor from back of the hood! Their is a rubber stop in the center back of the hood, it was stiking out to much letting water come in.
When I removed the new distributor cap the electrods where bad. After cleaning, it runs GREAT
Thanks for your sugestions..
The pick coil if ok.The problem was that when it rained, water was getting on the distributor from back of the hood! Their is a rubber stop in the center back of the hood, it was stiking out to much letting water come in.
