EGR saga - Part II - Vac results
Old Apr 19, 2005 | 05:12 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Once again, 88 TBI, EGR problem - poor performance, misfiring, etc.
At idle - no vac. At CRAWLING speeds, just the slightest amount of throttle, and I'm at 50-60 KPA (or between 15 and 18 inches). I'm not talking about cruising, I'm talking about just enough throttle tip in to get the vehicle moving at a slow pace.
Should I be seeing this vac at such low speeds from BEHIND the solenoid? In front of the solenoid I get about 60-70 KPA. If not, where would you go with this problem? Bad solenoid... 5 days old, or ECM grounding for no reason, or other?`
Old Apr 24, 2005 | 11:43 AM
Vader's Avatar
Disconnect the electrical connector at the EGR solenoid. Test drive it again. If the problem persists, disconnect the vacuum source from the EGR solenoid and cap it. Test drive again. One of those should help isolate the problem.
LT1Formula
20
Nov 14, 2015 12:02 AM
mdtoren
Aug 23, 2015 12:52 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
