AC not operating - let me explain the prob
Old Apr 20, 2005 | 02:43 PM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
My Heater works great, when I slide it to AC the compressor is not cycling at all. I checked to see if there was any refrigerant in the system and the gauge shows it is filled to the right pressure amount. Is there a fuse that can go somewhere or is the compressor mounted on the motor shot? Any help is appreciated.
Tony
Old Apr 20, 2005 | 03:43 PM
Charman234581's Avatar
Car: '88 Camaro RS,
Engine: 305 TBI
Axle/Gears: Stock
You should have an A/C relay on the car...also a fuse in the fuse panel. Try those before you assume the worst.
Old Apr 20, 2005 | 04:49 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
It could be the cycling switch. I have had to replace it a few times.
Old Apr 20, 2005 | 07:52 PM
Car: 1986 Iroc-Z
Where is the cycling switch located at and also AC relay so I can check them out. Thanks
tony
Old Apr 21, 2005 | 02:11 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Check the pressure switch located on the receiver dryer. Take a small length of wire and try jumping the compressor and see if that does anything...just a thought.
Old Apr 22, 2005 | 06:53 AM
Car: 1986 Iroc-Z
It does not, the autozone guy suggested that to. I am buying the relay tofday and putting it in, if that does not work I am taking it into to have the system checked from top to bottom.
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
Royal_Z
Sep 30, 2015 08:45 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
