running victor jr manifold
Old Apr 20, 2005 | 03:30 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
where or how do I hook up the vacuum line for the power brake booster?
there is no acc. hole for hose fitting in intake
Old Apr 20, 2005 | 03:39 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You can tee off of the PCV port on the carb.
Old Apr 20, 2005 | 03:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Of course not.
It's a race car part. Race cars don't generaly have power brakes.
If you need it, make it. Drill a hole and tap it to ¼" pipe. Facbricate. That's what racers do.
Old Apr 20, 2005 | 03:48 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
so just drill and tap a hole in where?
one of the runners in rear or what?
and my carb has no pcv port already thought that
Old Apr 20, 2005 | 04:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Front/rear/side of the plenum
Old Apr 20, 2005 | 04:07 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Just drll and tap where ever you want. You could even do it on a runner, but i wouldn't. Just pick a good location on the plenum that won't be in the way of anything.
Old Apr 20, 2005 | 10:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Do like RB says... in the manifold's plenum, drill a hole, tap it for a fitting, install said fitting, and hook up your hose.
Old Apr 20, 2005 | 11:09 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
So, did you tap that ho already? Does she suck or blow?
Old Apr 21, 2005 | 02:58 AM
EvilCartman's Avatar
Car: '82 Z28
Never tee off for a brake booster, it needs it's own dedicated vacuum line to work right.
Old Apr 21, 2005 | 03:11 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I did it before when i swapped my Q-jet for a holley on my original iron intake.
It worked fine for me, but i was also pulling 21 psi vacuum.
My new Weiand intake has a 3/8 NPT hole in the plenum.
Old Apr 21, 2005 | 11:39 PM
Car: '82 Z28
Just because it seemed to be working doesn't mean it was working properly. I've tried it, the brake pedal was a lot harder and that was with 15 inches of vacuum.
Old Apr 22, 2005 | 07:19 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
You can get carb spacers with the hole for a vaccum line also, but if your running a stock hood spacers might not be an option.
I've personally taken 3 of my different spacers-drilled/tapped them so I did'nt have to molest the intake.
Old Apr 22, 2005 | 10:43 AM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
thnaks for the info everyone
would it work well if I put a fitting on a runner?
and would it hurt anything perfromance wise?
Frozer!!!
Jan 19, 2024 04:55 PM
transaero
Aug 31, 2015 01:14 AM
Bstrang6
Aug 26, 2015 11:39 AM
86IROC112
Aug 17, 2015 02:00 PM
Jake_92RS
Aug 11, 2015 10:39 AM
