Knocking L98
Old Apr 23, 2005 | 03:41 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 3.73
Knocking L98
I just noticed today that my car is making a slight knocking noise (not a usual knock from lower octane) and I really have no clue what it could be. My father said it could be a lifter. The car runs great but I have noticed a small loss in power (if that makes any difference in diagnosing the problem). Any help would be greatly appreciated.
Old Apr 23, 2005 | 07:01 PM
sellmanb's Avatar
Car: '86 Berlinetta
Take the valve covers off, and check to see if a rocker arm is loose, maybe you pulled a rocker stud. Or a bent pushrod... worse case scenario with a knock is bearing clearances are shot.
Old Apr 23, 2005 | 11:49 PM
onebinky's Avatar
How loud is it? Deep tone, hollow tone, light ticking, rapping? Does it come at engine speed? Twice engine speed? Only under load, all the time, or just idling? Intermittent, only cold, constant?
Old Apr 24, 2005 | 03:32 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
I looked at it some more today and it appears to just be an exhaust leak from the collectors. There was no noise from the engine compartment and I could clearly hear the "ticking" noise from the collectors. I guess my father just got me imagining things. Thanks for the help.
RedLeader289
May 28, 2019 01:47 PM
FormulasOnly
Jul 23, 2018 08:47 AM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
