Dumb question on ZZ4 SB and cam install?
Old Aug 7, 2001 | 09:57 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
This is probably one of those dumb questions, but its been 14 years since I last had a SBC apart. I just got a ZZ4 short block and there is a oval plate over the cam journal with a "star" bolt on each side at 3 and 9 oclock. The plate has a hole in it, is this plate used to keep the cam from sliding in and out once installed, or is it just the protect the outside journal during shipping and should be removed and discarded?
If it is to be discarded, what holds the cam in place to keep it from sliding in and out?
(The only motor I've had apart in recent memory was my turbo6 and it has a cam buttom which is spring loaded between the cam and front cover)
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
79 TA 6.6l - all original stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, 12.40 @ 108 w/1.79 60'
95 Trans Am Conv.- LT1
Old Aug 7, 2001 | 10:10 PM
Guest
Guest
Posts: n/a
Its supposed to be there, part of the factory roller cam setup.
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Yes, thats the cam retainer plate.
You need it
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Aug 7, 2001 | 10:39 PM
2QUIK6's Avatar
I see after I looked at the cam closer, there is a recess in the front and the timing chain gear has a bearing plate on the back side which will glide up against it.
Thanks ya'll, I knew it was a pretty dumb question but wanted to make sure. I guess the non-rollers don't have this? as I sure can't remember ever seeing it before. This is my first roller setup install. Probably have a few questions about the lifter/rocker arm install/adjustments later.
Thanks again...
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
