major computer problem?
Old Apr 25, 2005 | 09:59 AM
bcp19's Avatar
Car: 1985 TA
Engine: L69 305 H.O.
I have a 1985 Trans Am, 5 sp with the L69 engine and recently I had the check engine light come on permanently. Since the light came on, the cruise control no longer works, and when cold, the engine acts like it's got a rev limiter on it around 3000 rpm. I took my car to auto zone, but they were unable to read the codes on it, plus when I put a jumper between pins a and b, the light does not flash, but stays on solid.
Is this a possible computer problem? Any help would be appreciated.
Old Apr 27, 2005 | 03:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like a dead 'puter.
Old Apr 27, 2005 | 03:07 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
One of the times my computer went south it acted like it had a rev limiter because it wasnt advancing the base timing, that may be a place to start. If it is bad get a computer from the boneyard. The first one i replaced eith an autozone computer it failed in 3 1/2 months, it had a 3 month warranty , so the second time i went to the junkyard 40 bucks no problems since.
Old Apr 27, 2005 | 03:51 PM
bcp19's Avatar
Car: 1985 TA
I've never gotten this deep into the car, where is the computer (ECM?) located at? Is it very easy to get to?
Thanks.
Old Apr 27, 2005 | 06:30 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
the ecm is located on the passenger side, behind the panel that has the floor light attached to it. This should be secured down with 7 mm hex heads, along with the ecm itself.
someone972
Aug 30, 2015 12:52 AM
stalkier
Aug 21, 2015 01:54 AM
jharrison5
Aug 19, 2015 05:53 PM
Bryan F
Aug 18, 2015 02:28 PM
zeitghaist
Aug 18, 2015 07:33 AM
