350 or 383 ?
Old Aug 7, 2001 | 05:42 PM
jim86's Avatar
350 or 383 ?
I will be building a new motor for my '86 Z28 this fall/winter and i'm debating whether to do a 383 or 350. I will be starting from an '84 4-bolt 350 block. My concern is that the 383 will require a host of other mods i am not ready for or would like to avoid,if possible. And probably my biggest concern is emissions. We have a pretty good test in Northern Ohio. To my thinking, i would have to dump the 19lb injectors, and maybe the 7 5/8 rearend (at least eventually). My 700-r4 might be in serious jeopardy also even though i just got a performance rebuild on it. I think i could squeeze by with both these with a 350. I also run street tires (P255/50/16 rear) and do not plan on running slicks. This would be a TPI motor.
I would be interested to hear from people who have 383's as far as emissions and what parts needed replacement to handle the extra torque. The motor will get a performance cam and aluminum heads(not sure which ones yet).
I would like the car to run the 1/4 in the low 13's, maybe the occassional high 12.
Old Aug 7, 2001 | 05:51 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
ttt
1986 Camaro Sports Coupe
T-tops, power hatch, rear defrost, third brake light
LG4 305 V8, Hooker Shorty headers, 3" pipe into Walker Quiet Flow dual exhaust
Edelbrock Performer intake, "Damonized" Q-Jet 4bbl, K&N filter
Crane ignition kit, TH700R4 transmission and Derale cooler
Air conditioning, power windows, ppwer doorlocks, power brakes, power steering, tilt wheel
Kenwood cassette, Pioneer 6x4 component front speakers
Rockford Fosgate 6x9 Punch rear speakers
Z-28 front and rear sway bars
Aluminum slots and Goodyear 225x60R15 Eagle HP tires
243 horsepower and 326 fp torque at the flywheel
_ _ _ _ ______ _ _ _ _
Yea verily, and he smote the smog demons from his small block Chevy, even from the air pump to the converter ...
Todd 1:1
Old Aug 8, 2001 | 02:35 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I'm doing an eagle 388 buildup now. http://www.geocities.com/joelol75 All the problems I had were minor, I had to grind some off the back pan rail for clearence and the rod nuts lightly scrubbed the bottoms of the bores and #2 and #6 rod bolt tops rubbed the camshaft. You might not have probs with a smaller cam (Mines 234 dur 292 adv 114 LSA)
Just a quick test fit (I saved some old bearings just to rest the crank on, and with a rod and piston combo (No rings) Fitted each rod to the crank and spun it.
Once you're sure, then use the new bearings. These kits are beutiful, just make sure to get it balanced, they are a MILE off!!!
[This message has been edited by JoelOl75 (edited August 08, 2001).]
Old Aug 8, 2001 | 05:28 PM
jim86's Avatar
anyone else ???
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
angel2794
Sep 8, 2015 06:22 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
