What size tap do I need for crank snout bolt hole on a 400sb?
Old Aug 8, 2001 | 05:29 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I was pulling my harmonic balancer off to install the new cam. I couldnt find the piece for the tip of my puller. I got it off but I screwed up the first two threads on the crank snout. Now the bolt wont go in that holds the balancer on.
It doesnt look to bad so I think I could use a tap to clean it up.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Aug 8, 2001 | 05:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
7/16"-20 (fine)
ICON Motorsports
Old Aug 8, 2001 | 05:50 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Thanks alot RB! I thought you would know. IM off to pepboys......
Old Aug 8, 2001 | 06:29 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
The tap worked I can get the bolt in. I need to run a tap thru the head bolt holes in the block. Do you happen to know what that one is?
Old Aug 8, 2001 | 06:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
But of course... 7/16"-14 (std thread)
ICON Motorsports
Old Aug 8, 2001 | 07:49 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Thanks! If I can help you with anything please let me know.
You have been alot of help to me with my 400 buildup.
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
