How Much Horsepower On Stock Fuel Pump And Rails
Old Apr 30, 2005 | 08:35 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
I will be building a 400+ HP small block for my 89 GTA soon. I am wondering what are the capabilities of the stock fuel system. Will i need a higher flow fuel pump, or what about rails, I will be getting 30# injectors.
My motor:
TFS 23 degree Kenny Dutweiler Heads CNC 64 cc.
LPE 219 cam with 1.6 roller rockers.
10.5 compression pistons.
LPE SuperRam intake system
BBK dual 58 mm throttle body.
Everything ported and gasket-matched.
SLP 1 3/4 headers
Old May 1, 2005 | 12:46 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
The fuel rails will be fine with your current combo. The fuel pump depends on what pressure you are running. If you are running close to stock fuel pressue...and the stock pump is able to keep up, then don't worry about it.
HTH,
Old May 1, 2005 | 03:41 AM
pellmanm's Avatar
Car: 1989 GTA
Thanks, i don't know what fuel pressure i will be running until i get the motor tuned, but probably around 50psi.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
