2 questions for you guys
Old Aug 11, 2001 | 01:15 PM
brian86Z's Avatar
my first question is about engine run on. why cant i get rid of it?? i have a carbed 383 that 25% of the time when i shut it off it like to spit and sputter a little while and then shut off. i have double checked timing and reset all the valves. i dont know what makes it run on like that.
my second question is what is the black crap that comes out of the exhaust and on to the garage floor? i have never seen the car smoke before but for some reason there is black stuff on the floor by the exhaust tips where i start it up each morning.
thanks
Brian
Old Aug 11, 2001 | 01:38 PM
ede's Avatar
ede
try adjusting the carb the black stuff on the floor is most likely condensation from the combustion process and a rich carb.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 11, 2001 | 08:51 PM
coach's Avatar
As far as your engine's run-on problem(dieseling), I'd try using a higher octane fuel. I had a carbed camaro that didn't like regular gas(87 octane or so). I had the same problem until I went to higher octane fuel. What octane fuel do you use? What is your engine's compression ratio?
Old Aug 11, 2001 | 10:50 PM
iroc5speed's Avatar
dieseling is usually due to a rich carb and maybe a vaccuum leak.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 14, 2015 08:25 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
