Mystery pistons?
Old May 1, 2005 | 07:17 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Mystery pistons?
I recently received a set of 8 327" SBC pistons, as the owner had no use for 327 pistons and go tired of them setting around his shop for "years".
Well they turned out to be 350 pistons, cast aluminum, with a pop up measured at .175" and very deep valve reliefs. The only identifing marks I can find are a stamped .030 (30 over), four stamped R, and four stamped L. The cast letters on the back side of the skirts "LIFELINE".
My real qusetion is; how do I determine the piston top displacement in cc's? These pistons appear to be very old.
Thanks, Andy
Old May 1, 2005 | 07:22 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
How do you know they're 350 pistons? The only diff between a 327 piston and a 350 piston would be compression height. 1.56" compared to 1.675"
And the only true way to measure them is in a block attached to a rod and the crank that's going to be used. You have to measure them as if they're flat tops, minus the difference that the volume of the dome takes up.
Old May 1, 2005 | 07:33 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Using the methods you have mentioned, they have been determined to be 350 pistons.
Old May 1, 2005 | 07:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
One simple way, would be to use a beaker or something, with graduated markings on the sides; fill it to some convenient mark; lower a piston into it; see where the fluid level goes to.
Another way would be to get some graph paper with 1" or 1cm grid lines, preferably divided down to .1" or 1mm; lay it over the dome, trace the dome on the paper, and count the squares, then multiply by the dome height.
This is not rocket science here, it's just car parts.
Old May 1, 2005 | 07:43 PM
ANDYZ28's Avatar
Car: 1982 Z-28
I thought of using the beaker method, but air will become trapped in the valve reliefs.
I realize it's "not rocket science", but I thought that knowing the compression ratio might be helpful to me later.
Old May 1, 2005 | 07:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Then measure the valve relief volume with a head cc'ing buret or a syringe or a pipette.
Don't try to outsmart yourself.
Old May 1, 2005 | 07:46 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Thank you
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Gordonr1973
Sep 29, 2015 11:59 AM
