thermostat question
Old Aug 12, 2001 | 08:33 PM
ihateallmustangs's Avatar
thermostat question
i heard that some guys drill small holes in their thermostats to improve the flow of the coolant..does it actually help keep your car cooler? or is it all a bunch of b.s.?
Old Aug 12, 2001 | 08:50 PM
Vader's Avatar
Whether or not it helps to keep the car cooler is ont a proven point, but what it can do is allow a small amount of the coolant flow constantly to the radiator. This will presumably allow the thermostat to open a littl sooner than would be otherwise. Robertshaw used to have a small weep hole in many of their thermostats, with a small floating surge valve in the hole. Their theory was the same.
The holes can also help expell air from the cooling system when it is filled, or if it may become low for whatever reason. Personally, I would think that a single hole wouls serve the function almost as well as several.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
italiano67
Dec 11, 2016 09:21 AM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
redmaroz
Aug 16, 2015 11:40 PM
perZ
Aug 15, 2015 01:17 PM
