Bad alternator?
Old Aug 13, 2001 | 04:40 PM
89Firebird Formula350's Avatar
Bad alternator?
I started my car today and it didn't start. I jumped it and it started. I made it about a mile down the road, and it died on me. Is this a bad alternator? It keeps dying and won't run.
Thanks!
Old Aug 13, 2001 | 04:56 PM
RW91B4C's Avatar
Does your car have a volt guage?
What does it say - if its less then 12.5 volts while the car is running then its probably the alt.
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.92@125.2 1.55 60FT. ON MOTOR - ET-STREETs w/MUFFLERS
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
Sure does sound like a bad alternator to me.
If you have a volt meter.....
Check the battery voltage with the engine off, it should read approx. 12volts.
Start the engine and check the battery voltage again. It should now be approx 14 to 15 volts.
If it does not rise then you could have a faulty alernator.
Also check the tension on your belt as well. If your belt is loose then it might be slipping enough to the point the battery is not charging.
I just replaced my alternator this weekend. I got lucky though. The bearings went bad on it and it was easy to spot the problem.
Old Aug 13, 2001 | 05:58 PM
Eddie's Avatar
Best way to check is to start it and unhook the positive terminal if it is the alternator it will die if it runs on then it could be the battery. There also have been alternator problems that come and go which I have had, best bet would be to get it rebuilt or get another.
Old Aug 13, 2001 | 06:02 PM
Eddie's Avatar
By the way I am pretty sure they should run at 14 volts normally that is what I get at my alt. and at the bat., I have checked this cause I have a bad gauge on the dash.
Hotrodboba400
Dec 10, 2019 07:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
sahlomonic
Sep 20, 2015 07:15 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
