High Pitched Tone When Gas Pedal Depressed
Old May 4, 2005 | 08:47 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
'89 Lo3. When I am going 40+mph and i push on the gas pedal, there is this high pitched tone emmitted. When I let off the gas, it stops. My moms '02 Ford Explorer did this and they had to rebuild the rear end. Why is mine making this noise?
Old May 4, 2005 | 11:55 PM
sellmanb's Avatar
Car: '86 Berlinetta
how much fluid is in your rear differential?
Old May 5, 2005 | 07:02 AM
Car: 1988 Camaro
Engine: 350 V-Eight
Dont know
Old May 5, 2005 | 09:38 AM
sellmanb's Avatar
Car: '86 Berlinetta
There should be a fill plug and occassionally a drain plug as well. If you take the fill plug out and stick your pink in it, if it has less than up to your last knuckle (the one right by your nail) then it's too low.
Also, rear diff fluid is very clear when put in there. If it comes out sludgy or something then you will want to replace that anyways. I find that rear differentials are the most neglected part of a car.
Old May 5, 2005 | 12:27 PM
Damon's Avatar
There's oil in the rear end?!?!?!?
I never knew that.
Learn something new every day, I guess.
(I'm kidding, just kidding!)
Where is this "high pitched tone" coming from? Up front? Out back? Can't tell? Is it only in a certain gear or at a certain RPM or at a certain MPH?
I wouldn't necessarily jump to the conculsion that the rear end is going out based on what little info is in this thread.
Old May 5, 2005 | 03:00 PM
Car: 1988 Camaro
Engine: 350 V-Eight
It seems to be there at all speeds, but only when i have my foot on the gas pedal. Im not sure but i think it is loudest at 40-50mph. I realy havent drvin in faster than that yet, but i think it might actually get quiter past 55mph. as soon as i let off the gas, it stops.
Old May 5, 2005 | 03:06 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
If coming from up front you could also have a vac leak...
Old May 6, 2005 | 06:13 AM
Car: 1988 Camaro
Engine: 350 V-Eight
Im pretty sure its coming from the rear of the car, and is loudest at 45mph
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Sep 21, 2015 09:57 AM
theshackle
Aug 31, 2015 10:47 AM
johanlindgren
Aug 16, 2015 12:16 AM
